The differences between L/H and R/H benders
Post by mcbob » Sun May 24, 2009 1:51 am
Would i be correct in assuming the the only difference between the left hand and right hand US 820's is the flywheel and it's keyway position or could you use a counterclockwise engine and just add a clockwise flywheel ..... or is the crankshaft cam lobe different for the points activation.
Re: The differences between L/H and R/H benders
Post by Rob Voska » Sun May 24, 2009 7:18 am
Point cam is different.
Post by mcbob » Sun May 24, 2009 4:11 pm
Well thanks Rob
Looks as if i'll have to get a left hand flywheel and do my electronic ignition conversion using the Ryobi module as i have another extreme build in the thought process i'm going to mount two Copperheads together like i did my twin 101 and i'm sure a centre drive clutch and chain drive will help in the handling and balance department.
McBob.
Tom Luttenbacher
Vintage Karting items owned: Dart A Bone, Neal, LeeKart, Lancer, GoKart 800's, Simplex, Blitz.
Post by Tom Luttenbacher » Sun May 24, 2009 6:18 pm
McB, when you couple these motors do you have the pistons firing 180 degrees apart? I ask because if they are firing both at the same time why not use one ignition source, use a flywheel, but no ignition on one of the engines? Two coils/ign mounted to one motor? Tom
Post by mcbob » Sun May 24, 2009 6:40 pm
Tom Luttenbacher wrote:McB, when you couple these motors do you have the pistons firing 180 degrees apart? I ask because if they are firing both at the same time why not use one ignition source, use a flywheel, but no ignition on one of the engines? Two coils/ign mounted to one motor? Tom
Na both engines will be independant only coupled by two clutches like in my Twin Mac 101 plus i haven't seen a twin coil that would do what you are talking about and by using two clutches there's less chance of breaking cranks as i believe when you run a solid coupling thats the hassle you face even though you can then sync the two engines it's food for thought though i think i recall having that conversation with Gordon Daux sometime back.
This saw if setup the way i have in mind will have the left hand engine carrying the oil tank which is also the bar and chain mount so it will be a centre drive Twin thereby helping with good balance and easier better control.
I have done a mockup on my kitchen table ( no missus to interferr ) and i'm pretty certain it will work.
It's early days yet as i'm sure i have sold my Twin Mac 101 so now i have to build another more powerful beast cant have him thinking he's got the best !!!!
Post by Rob Voska » Mon May 25, 2009 8:44 am
Put a new keyway in a std flywheel. Magnets will need re-zapped to change north, south poles.
