spark plugs
Mike Anderson
Rathman xterminator (3)
margay cheetah dual (1)
Blackstone Special (1)
spark plugs
Post by Mike Anderson » Thu Jan 05, 2012 8:21 pm
Hi All,
I have a quick question. What plugs are being used in the Mac's now a days. I recently have used the Autolite 262 and411 plugs which were the updated A-901 and ae-901 but the 262 is no longer listed. Does anyone have a substitute which is working for them?
Thanks Mike Anderson (317)729-2418 fleagle14@embarqmail.com
Re: spark plugs
Post by ted johnson » Thu Jan 05, 2012 9:19 pm
Mike, Ron and I have had exceptional luck with NGK. The B7S is a hotter 3/8" reach, the B7HS is the hotter 1/2". These are gas plugs. The B8S, B9S, B8HS and B9HS are the corresponding alky plugs. The "H" denotes the 1/2" reach. The higher the number, the colder. Hope this helps. Ted
Mike Anderson
Re: spark plugs
Post by Mike Anderson » Fri Jan 06, 2012 6:43 am
Hi Ted,
Thanks for the quick response. Hope you had a great holiday.
Later Mike
Re: spark plugs
Post by Rob Voska » Fri Jan 06, 2012 7:38 am
Been using the 411's with alky. Should install a hoter plug for flushing as it seems to foul a 411.
Re: spark plugs
Post by ted johnson » Fri Jan 06, 2012 9:05 am
Thanks, Mike. The Holidays were warm and very relaxed. Hope (maybe) to see you and Rob at TBO. Gotta get some hours on that Nike! TJ
